(10.09.26) DAILY MISSION: Tavern Riddles 10.0
:beer_mug: Tavern Riddles
The hooded patron sits in his usual corner, balancing a small silver dagger on the tip of one finger. As you approach, he flips it into the air. Before it can strike the table, the blade vanishes beneath his sleeve.
“Ah, there you are. I’ve got one that might make you think twice before opening the next door.”
He leans forward…
  • :puzzle_piece: Solve the riddle!
  • :speech_balloon: Did any clue give it away?
LE RIDDLE
I have no feet, yet I guard the way.
I have no eyes, yet I know when you stray.
Some seek to break me, others turn away.
One wrong move, and there’s a price to pay.
What am I?
The riddle solution:
A door lock
A lock blocking the way
Not quite a lock, gamers! Keep trying!!
Most of it sounds like a combination safe but that wouldn’t fit the clue for guarding the way so well.
The answer is a boundary, for example the edge of the area of play.
I’ll try my answer with a door!.
Is A trap the correct answer
This would be a Gate.
@Morethanplanet2
A door lock :slight_smile:
