(11.03.26) DAILY MISSION: Tavern Riddles 12.0!
:beer_mug: Tavern Riddles
The hooded patron sits in his usual corner, balancing three copper coins across his knuckles. As you approach, he catches them all in one hand and chuckles.
“Ever traveled with a warrior who insists on being the first into battle? Brave fools, the lot of them. Always shouting, swinging, and making certain every beast in the room knows exactly where they are.”
He slides a coin across the table.
“Here’s a little something for those who’ve spent time in a dungeon or two.”
  • :puzzle_piece: Solve the riddle and share your answer!
  • :magnifying_glass_tilted_right: Explain which clue led you to your conclusion.
🧩 LE RIDDLE
I have no sword, yet battles I command,
The fiercest foes will follow where I stand.
A warrior seeks to keep me in their sight,
While reckless heroes steal me in a fight.
A healer’s kindness may draw danger near,
And send the bravest running off in fear.
Hold me steady, keep your allies free,
For chaos comes when foes abandon me.
What am I?
    Difficult - I’ll try with ‘aggro’.
    “Hold me steady, keep your allies free”
I was tempted to try with shield, but it doesn’t fit as good.
Crossing fingers!
Aggro
If it commands battle while not being a sword and Healers can attract danger, then it can only be aggro. It’s the only thing that would control a fight while always being high risk for healers.
I think that this is a tank.
I can only think of.. Hope?
The answer is…
drum roll
CLICK ONLY IF YOU WANT TO SEE THE ANSWER
Aggro
Aggro
