9060 xt 16 gb
It’s almost been a full year using this GPU, while I’m very happy about my purchase these are some of the problems I’ve encountered so far..
INSTANT REPLAY:
There seems to be an issue where the clip is missing audio around the last few seconds using the default high preset, which uses AV1. I switched encoding from AV1 to HEVC and audio channel from Auto to Stereo and this seems to “solve” the problem.
IN-GAME OVERLAY:
The overlay works properly until you tab out to another window or after an hour or so it would randomly turn off. Shortcut for overlay also doesn’t work after it times out. Tried everything from uninstalling and reinstalling drivers, same issue. Restarting my pc fixes the problem up until it randomly times out again.
FREESYNC PREMIUM:
I’m using a duo setup with a 165 Hz LG Ultragear monitor and a 75 Hz Acer monitor. Alt+Tab and Windows+Tab sometimes break freesync. The stutters don’t stop until you close and reopen the game. Same thing happens regardless of using Fullscreen or Borderless.
