CS2 Counter Strike 2 Start Parameters and Tweaks
Hello,
i want to share my startparameters for CS2 with you, with these i had the best performance experience without any lags or micro stutters:
-tickrate 128 -nojoy -freq 240 -softparticlesdefaultoff -exec autoexec.cfg +fps_max 0 -forcenovsync +r_drawparticles 0 -limitvsconst +engine_low_latency_sleep_after_client_tick 1
  • Disable Boost
  • Disable FSR
  • Disable FreeSync, VSync, Gsync
  • freq 240 = should fit ur Monitor Refresh Rate
I used these with an AMD Ryzen 7 9700X and GeForce RTX5070.
Thanks for putting this together. One heads-up: -tickrate 128 is a leftover from CS:GO and does nothing in CS2 since Valve switched to sub-tick, so you can safely drop it. Also, with +fps_max 0 and freesync/gsync off, just watch for tearing when frames dip below 240, so it can be worth capping slightly above or below your refresh rate.
