Did you guys noticed my complains ? About the defective Integration of the Frame Generation feature in The game “Cronos The New Dawn”
since the first time I got my 9700 XT, I’m getting crashes all the time. I hate to go through a special procedure, to avoid crashing.
So when I’m playing the game, with frame generation and fluid motion activated in the driver, it crashes all the time. It could be a half or a full hour.
I must deactivate this two features in the game menu, when I still playing. Before I exit the game. It doesn’t matter if I quit the game to the menu or directly to the desktop.
Sincerely I’m more than saturated to this issues. But for my sake I have two more computers. Powered by the green cards. . Where I can play there the game without any issues. I call them the first of my two Battle Stations. It’s the flagship computer. Equiped with a Fury RTX GeForce 4080 Super.
The last computer is one gaming Laptop. With one RTX GeForce 4090 Mobile. The both Battle Stations has a fair Underground, they’re fired up with the same CPU. The Ryzen 5700x3D. The Lappy has one INTEL CoreI9-11900 HXA
Best regards from Germany.
P.S.
I’ve tested the Radeon card with many games. And all of them works flawlessly. No one shows any errors. So till nowadays it’s only this peculiar game I mentioned above
Quick question: are you running the game’s own frame generation and AFMF at the same time? Because those two really don’t play well together. If a game already has its own frame gen, AFMF in the driver should stay off, and vice versa.
I’ve had the exact same crashes you’re describing when both were on by accident, and turning one of them off fixed it completely for me. Worth a try before anything else, especially since everything else runs fine for you.
for FPS games like CS2, R6S, CoD … DONT USE
- NVIDIA Boost
- FSR
- VSync
- GSYnc
But it shouldt CRASH …
You can use DDU Display Driver Uninstaller for a clean DRIVER installation
That sounds really frustrating, especially since the 9700 XT works perfectly in your other games. If the crashes only happen in Cronos when Frame Generation and Fluid Motion are enabled, it sounds more like a game/driver compatibility issue than a faulty Radeon card. Hopefully the developers or AMD can reproduce the problem and fix the integration rather than requiring players to disable features every time before quitting.
For anyone looking for other gaming-related information, I’ve also found this game guide useful
That’s one nice suggestion. Yeah,
I think this could be the exact issue. But in other games I can let FG Frame Generation active on the driver. And in the game settings too. They don’t given any problems. So I’m guessing the studio hasn’t implemented this feature we’ll in their game.
