my new pc’s fps is very low in overwatch. i have tried to reset the settings but it does’nt work and changing the resolution does nothing and when i try to set the render scale up, my fps drops all the way down to 10. i can’t really find a solution my specs are the ryzen 9 9950x3d cpu the motherboard is a GIGABYTE X870E AORUS PRO ICE and for the ram i have some G.Skill Trident Z5 Neo RGB DDR5-6000 - 32GB. Thanks :).
Is your new PC only running low FPS in Overwatch? How is it running in other games? You should try a few to see if this problem is constant across some other games. Meanwhile, look for game patches for this game and also make sure you are running the latest recommended Adrenalin driver and chipset drivers for your PC.
