System
- GPU: Radeon RX 7900 XT (Sapphire, SUBSYS 471D1DA2), 20GB
- Display: single 3840x2160@160Hz over DisplayPort
- CPU: Intel Core i5-14600KF, 64GB DDR4-3200
- OS: Windows 11 Home (China), 26H2, Build 26300.9457
- Driver: Adrenalin 26.10.1, 32.0.32015.7029 (installed 2026-10-21)
Symptoms
When switching to a Bilibili (bilibili.com) video page, or when the page switches between the
main player and its mini-player (floating window), the ENTIRE SYSTEM freezes for ~15-20 seconds:
- screen frozen on the last frame (occasionally gray horizontal bars flash)
- mouse does not move
- keyboard LEDs (NumLock/CapsLock) do not respond to key presses
- system recovers by itself; no BSOD, no reboot
Event log evidence: NONE
- No Event ID 4101 (display driver timeout)
- No WHEA-Logger entries
- No Kernel-Power 41, no BugCheck
- No Application crash/hang events
- Performance counter collection also stalls: a 1-second sampling loop missed ~22 seconds
of samples exactly during the freeze, while CPU/disk/memory counters reported normal
values immediately before and after
Reproduction
100% reproducible, deterministic:
1. Open Edge, go to bilibili.com, open any video page
2. Switch to another tab and back, or trigger the site's mini-player
3. Freeze occurs within seconds, lasts 15-20s, then recovers
Workaround
Rolling back to Adrenalin 26.9.1 (32.0.31041.3013) removes the issue completely.
Everything else unchanged (same browser, same site, same settings).
Hypothesis (unverified)
VCN media engine power gating appears stricter in 26.10.1. Bilibili creates and destroys
decode sessions frequently (main player <-> mini-player), and a new decode session request
seems to land inside the power-gate window, causing the driver to wait.
Reference: AMD amdgpu kernel patches "drm/amdgpu/vcn: fix video profile race condition"
(Aug 2025) describe fence/submission counters reaching zero between decode jobs and the
driver switching the video power profile while another instance is still decoding -
same IP/firmware. I understand this is the Linux path and does not prove a Windows issue,
but it may be a useful pointer.
Request
Please check VCN power gating / workload profile handling changes between 26.9.1 and
26.10.1, and whether decode session creation during the power-gate window can block the
graphics pipeline.
Note
I cannot reinstall 26.10.1 to reproduce with the bug report tool, because the freeze affects
the whole system. DxDiag attached is from the current 26.9.1 state.
Thanks for such a detailed report, especially the clean rollback test and the note that no timeout or crash events were logged. That contrast between 26.10.1 and 26.9.1 makes the driver change a strong lead, so staying on the working version for now seems sensible. It would also be worth checking whether disabling hardware acceleration in the browser changes the freeze, since that can help separate a decode issue from a broader display problem.
Same issue here, confirming this is reproducible on a different setup.
Setup: RX 7900 XTX, Ryzen 7 5700X3D, 64 GB RAM, Windows 11 Pro Insider build 26300, single 3840x2160 @ 160 Hz, HAGS off. Chrome with hardware acceleration on.
Symptoms: whole-system freezes while watching video in Chrome, often for a long time. Sometimes the driver recovers afterwards, but several times the PC never came back and I had to hard reset (Kernel-Power 41, BugcheckCode 0). Unlike the OP, I do get logs: many LiveKernelEvent 0x141 (VIDEO_ENGINE_TIMEOUT_DETECTED) and 0x117 reports with WATCHDOG dumps, plus one dwm.exe crash in amdxx64.dll.
Driver results:
- 26.11.1 (32.0.32015.16001): freezes
- 26.9.2 (32.0.32015.2008): freezes as well (hang again right after downgrading to it)
- 26.9.1 (32.0.31041.3013): no freezes so far
Before rolling back I tried disabling MPO, Chrome HW acceleration, and Apollo/virtual display. None of it helped, only the driver rollback did. So for me the regression seems to start with the 32015 branch (26.9.2), not 26.10.1.
Will also file it via the AMD Bug Report Tool. AMD team, please take a look, this looks like the same VCN/video-decode hang.
