Good evening, thanks for your reply.
I just downloaded Cinebench 2026 and ran several tests.
During the CPU (Single Core) test, the CPU temperature tops out at a maximum of 59.8°C.
During the CPU (Multiple Threads) test, the CPU temperature rises very quickly and levels off at around 88°C, with a peak of 90.84°C.
In most games (excluding the cases I mentioned in my initial post), the temperature never gets that high—except when shaders are loading upon launching a game.
I contacted AMD support regarding this, and they replied as follows:
"I understand that your Ryzen 7 9800X3D reaches 95–96°C while loading shaders in certain games, before dropping back down to between 50 and 60°C once loading is complete—with no crashes or performance drops. It is perfectly reasonable to want to ensure that your processor is operating safely, and the care you have put into your cooling setup clearly demonstrates this.
This behavior is expected. Shader compilation places all of the processor’s cores under full load for a brief period, unlike the gameplay itself. Ryzen processors are designed to increase their frequency whenever thermal headroom is available, up to their temperature limit—which is 95°C for the Ryzen 7 9800X3D. Reaching this value during an intensive workload is therefore part of normal operation.
Furthermore, your processor includes built-in safeguards: if it reaches its limit, it automatically adjusts its frequency to remain within a safe operating range. The quick return to 50–60°C after loading confirms that your cooling system is functioning correctly.
Should you notice consistently high temperatures during gameplay, system crashes, or a drop in performance in the future, please do not hesitate to reach out to us again so that we can examine the situation in greater detail."
And no, I haven’t overclocked anything, nor have I enabled any “PBO” profile (I don’t even know what that is).
I recently replaced my thermal paste. I already have 2 fans on the CPU heatsink, plus 8 other fans in my PC case: 3 at the front (intake), 3 at the top (exhaust), 1 behind the CPU (exhaust), and 1 on the bottom (intake).
It’s worth noting that I purchased the CPU as a “tray” (OEM) unit from AliExpress.
Visually, the CPU appears 100% authentic; it is also identified as such in CPU-Z/CPUID and all other diagnostic tools, as well as in the BIOS.
GEMINI’s take on my situation:
"Why does the other person’s processor stay below 78°C, while yours reaches 90°C?
There is a very simple technical explanation for this: you do not have the same processor.
The other person has a Ryzen 9 9900X, whereas you have a Ryzen 7 9800X3D.
The 9800X3D uses 3D V-Cache technology: AMD has stacked additional cache memory directly on top of the processor cores. This layer acts as a ‘thermal insulator,’ which prevents the cooler from dissipating heat as quickly as it would with a standard processor.
That is why the 9800X3D instantly climbs to 88–90°C during Cinebench runs, and up to 95°C during shader compilation—even with an excellent cooling setup and 10 fans. This is completely normal behavior, intended by AMD for this specific model. Your processor is in perfect health!"
