What fixed it: After upgrading from Intel to an AMD X870E system, I experienced random USB audio pops and crackles while listening to music and playing games. Installing an LR-LINK LRSU9A72N-2A PCIe USB expansion card with a Renesas uPD720202 controller stopped the random popping completely on my system.
I’m sharing this because troubleshooting the problem took a huge amount of time, money, and frustration. I hope this post helps someone with similar symptoms find a solution sooner.
My hardware
I previously used an Intel-based PC and upgraded to AMD for better gaming performance.
- CPU: AMD Ryzen 7 9850X3D
- GPU: NVIDIA GeForce RTX 5090
- Original motherboard: ASUS TUF GAMING X870E-PLUS WIFI7
- Replacement motherboard: ASUS ROG CROSSHAIR X870E DARK HERO
- USB DAC: Matrix Audio mini-i Pro 4
- Studio monitors: Genelec 8331A
- USB expansion card that resolved the issue: LR-LINK LRSU9A72N-2A, using a Renesas uPD720202 USB host controller
The problem
After the platform upgrade, I started hearing intermittent, random pops and crackles through USB audio during music playback and gaming. They occurred during ongoing playback, not just when starting or stopping a sound.
Your DAC or speakers may be different from mine, but the symptoms may still sound familiar if you use a USB audio device.
What I tried without success
- Replacing the USB cable
- Trying different USB ports
- Using a TOPPING HS02 USB isolator
- Updating the motherboard BIOS
- Changing CPU power-saving settings
- Reinstalling the Matrix Audio USB driver
- Replacing the entire motherboard
The most expensive attempt was replacing the TUF motherboard with a ROG CROSSHAIR X870E DARK HERO. The random USB audio popping continued even after that motherboard replacement.
Two comparisons helped narrow things down:
- Optical/S/PDIF playback did not have the random crackling during continuous playback.
- The same DAC worked normally over USB on another computer.
What finally worked
I installed the LR-LINK LRSU9A72N-2A, a two-port PCIe USB expansion card with its own Renesas uPD720202 host controller, and connected the DAC to the card instead of the motherboard’s USB ports.
The random pops and crackles disappeared.
The DAC is connected directly to the expansion card, with the TOPPING HS02 isolator removed.
The relevant detail is that this is a PCIe card with its own USB host controller. A regular external USB hub does not make the same change to the computer’s USB connection path.
What I would suggest to someone with similar symptoms
If you have a similar AMD AM5/X870E setup and random USB audio popping or crackling, especially if the same DAC works normally on another computer, I would put testing a compatible PCIe USB card with its own host controller much earlier in the troubleshooting process—before spending a lot of money replacing the motherboard.
This completely resolved the issue on my configuration. I have not established the exact underlying fault, so I cannot guarantee the same result for every system.
The whole experience was exhausting, and spending so much money on a different motherboard only to hear the same popping again was especially frustrating. I’m relieved to have finally found a working solution, and I hope sharing it saves someone else the same time, expense, and frustration.
