Title: How can I reduce dust buildup and improve cooling in my AMD PC?
How can I reduce dust buildup and improve cooling performance on an AMD-powered PC?
I have an AMD-based desktop PC that I use regularly, and I’ve noticed that dust can build up around the case, fans, and vents over time. What is the recommended way to clean the exterior and surrounding area without damaging the components? Also, are there any AMD-specific recommendations for maintaining good airflow and temperatures?
  1. Dont Smoke in the room where ur machine is running
  2. Vaccum Cleaner for the easy accessable parts and a electric air duster from time to time for the rest (use it on your balkony)
  3. every 3/5th year fresh thermal paste for the CPU/GPU not neccassary with newer hardware
