The Restart Hierarchy
Something on your PC isn’t working. Nothing catastrophic, just enough weirdness to be annoying. Before you start Googling error codes or questioning every decision that led you here, there are a few sacred troubleshooting moves we all reach for.
Rank these troubleshooting moves from FIRST thing you’d try to LAST:
Hard Restart the PC
Unplug the router and plug it back in
Check settings / connections
Check for updates or drivers
Search the problem online
0
voters
Every tech problem has a solution, and somehow half of them begin with turning something off and back on. What’s your go-to troubleshooting move that works suspiciously often? ![]()
