Error with custom color configuration
In adrenalin 26.3.1, after configuring a custom color for a specific game, it affects the global settings,
The issue manifests as the global colors still using the game’s custom colors after exiting the game, and solving this issue always requires manually closing the affected global custom colors.
Yeah, whats the going on? Seems like it would be an easy fix for this?
AMD, hello? =P
Me too.
It seems that this issue can be temporarily resolved by downgrading the version
Have you guys ever tried the PRO Driver Setup ?
https://www.amd.com/en/resources/support-articles/faqs/PDH-INSTALL.html
AMD Cleanup Utility ?
https://www.amd.com/en/resources/support-articles/faqs/GPU-601.html
One workaround besides downgrading is to reset your global color settings back to default right after exiting the game, then save the profile so the per-game colors don’t carry over. Also worth reporting this through the bug report tool inside Adrenalin so it stays on their radar for a future driver release. Hopefully they fix the profile handling soon since this has been reported for a while.
