Shadow calculation in Trackmania
Google translate : Hello, :waving_hand: I’ve attached my PC specs. I’d like to know why it takes me nearly an hour—sometimes even longer—to calculate map shadows on the “High” setting in Trackmania, whereas a friend of mine, doing the exact same thing on a PC powered by a Pentium processor, only takes a few seconds. I don’t understand why there is such a difference.
there was a way for batch and outgame calculation (via CMD or PowerShell command) of shadows but sadly the forums are offline where it was posted.
A good way is to calculate shadows at LOW - FAST just for publishing the maps.
I had the same CPU like you have but an RTX4060 and it was working fine.
Checkout these Links but also the official TM Discord
