Size limit for build pics?
Is there a picture size limit I tried uploading a 1.5mb image and it just sits processing and never stops?
Shouldnt be an issue, sometimes the formats of images can cause some issues like everywhere else. Let me know size and format and we can report bugs / issues to fix.
I have no problems uploading 2-3 MB images to this forum.
Hi! This usually doesn’t happen because of the file size alone, but because of the image dimensions or format. A 1.5 MB image should normally upload fine, but if the resolution is very high, the forum can get stuck while processing it. Try resizing the image first (for example to 1280×720 or 1024×768) and make sure it’s in JPG or PNG format, then upload it again. In most cases, this fixes the issue.
I’ve also had this issue and resizing picture has not worked
